How to Apply Column-Specific Decimal Formatting When Exporting 2D Arrays to CSV in LabVIEW?
Updated Aug 11, 2025
This articles overlines the steps to customize number or decimal points for each column when converting an array to a spreadsheet string in LabVIEW and exporting the results as a CSV file.
Follow the steps below to implement column-specific decimal formatting in LabVIEW:
  1. Prepare the 2D array that contains your measurement data.
  2. Create a subVI that accepts a 1D array (representing a single column) and a format string as inputs. This subVI should return a formatted string for that column.
  3. Use the Index Array function to extract each column from the 2D array.
  4. Call the subVI for each column individually, passing a different format string depending on the required decimal precision. For example:
    - Column 1 (1 decimal point): %.1f
    - Column 2 (1 decimal point): %.3f
    - Column 3 (2 decimal point): %.2f
  5. Combine the formatted strings using the Insert Into Array function.
  6. Use the Array to Spreadsheet String function to convert the final array into a spreadsheet-compatible string.
  7. Save the result as a .csv file using the Write To Text File function.
