I am currently working on replacing a program that was created using LabVIEW 7 and NI-DAQ 7.5 with the latest LabVIEW and NI-DAQmx version. The process involves measuring frequency using both counter output and input. However, I do not know how to replace the following NI-DAQ function with NI-DAQmx function.
Function: Counter Set Attribute.vi
Attribute ID: Specifies which attribute that will be set (e.g., clock source, mode)
Attribute Value Type: Indicates the data type of the value passes (e.g., float, integer)
Using this function, pulses are counted with the counter input from when the counter output starts until it stops.
What NI-DAQmx function can be used to replace the above function?
