'NoneType' Errors When Calling LabVIEW ActiveX Server Methods with Python
Updated Aug 8, 2025
Programming Language
  • Python
I'm using the win32com.client module from pywin32 to interact with the LabVIEW ActiveX Server. I can successfully read and set values from controls and indicators using the SetControlValue and GetControlValue methods. However, when I try to execute certain methods like Run() or OpenFrontPanel(), my Python script fails with the following error:
TypeError: 'NoneType' object is not callable
I want to understand why this error occurs and how to fix it so that I can run the VI programmatically.
This error can happen when the method you're trying to call is not recognized as a callable method of the COM object or properly flagged as a method in the COM interface.
When using win32com.client.Dispatch, Python dynamically inspects the COM object based on its type library (TLB). If a method like Run is not explicitly marked as a method in the type library, Python may treat it as a property or return None. When you try to call it, you get the 'NoneType' object is not callable error.
To work around this, pywin32 provides the _FlagAsMethod() function. This lets you manually tell Python to treat the name as a method. For example, to prevent the error when calling the OpenFrontPanel and Run methods, include the following lines at the beginning of your code:
vi._FlagAsMethod("OpenFrontPanel")
vi._FlagAsMethod("Run")
