What Is the Licensing Behaviour for SystemLink Base?
Updated Oct 21, 2026
  • SystemLink
  • SystemLink Server
  • I have configured a SystemLink Base instance. What is the expected behaviour in the Licenses page?
  • Under what circumstances will a System or User license be consumed in SystemLink Base?
  • When will a System or User license be freed in SystemLink Base?
System Licenses
1 System license is consumed per Client system on the Systems Management page. If a Client system is removed from SystemLink, a System license will be freed up.
For example, the images below show that 2 Client systems are present in the Systems Management page, so 2 System licenses are consumed.
User Licenses
1 User license is consumed per Active User. An Active User is a user that has logged into the SystemLink web UI in the last 30 days. A User license is freed after 30 days of inactivity (i.e. no logins) from the respective user.
For example, the image below shows that 2 User licenses are consumed because 2 different users have logged into the SystemLink UI within the last 30 days.
SystemLink Base can be activated locally on the server machine using NI License Manager. SystemLink Base offers 2 types of licenses - Small or Medium:
  • The Small license (appears as SystemLink Base - S in NI License Manager) enables 5 different Users and 10 different Systems at a time.
  • The Medium license (appears as SystemLink Base - M in NI License Manager) enables 10 different Users and 25 different Systems at a time.
