In the NI PXIe-7891 specification, Low-Latency Analog Output range support ±10 V, ±0.5 V. This properties is supported for configuration.
How can we configure the channels output range to ±10 V or ±0.5 V?
I tried to use I/O method but didn't have method for output range.
The AO range is configured from the Host VI via the FlexRIO Channel property.
See the PXIe-7891 Basic Getting Started Example below:
Also note, this setting won't take effect until you call Commit:
