1. Here is a USRP-2974 with a Windows OS computer, as shown below:
2. The default FPGA image of USRP-2974 is an LVBIT file. To implement open source applications, you need to refresh the image ( BIT format ) for USRP-2974. The specific operation instructions are as follows:
3. Restart USRP-2974 after successfully refreshing the Image (X310_XG)
4. Connect the QSFP cable between the USRP-2974 SFP1 and the SFP port of the third-party PC; (Note: Only SFP1 port can be used because SFP0 will be routed to the internal computer)
5. Modify the IP address of the SFP port on the third-party PC as shown below: (The default IP address of SFP1 of USRP-2974 in XG image is 192.168.30.2)
6. In the Terminal window of the third-party computer, search for the UHD device, as shown below:
