1. Set up the host PC (Ubuntu OS) and connect the USRP X410 by the network cable for communication.
2. Connect the Host PC with the USRP X410 (CONSOLE JTAG) Port using a USB cable.
3. Remotely log in to the host PC through Teamviwer or Anydesk
4. Use Putty.exe to log in to USB2/3 respectively, as shown below:
Set the baud rate to 115200 and open below two windows:
5. In the SCU window, log in to the USRP by root
6. Send "poweroff" through the SCU window to power off the USRP X410.
7. In the APU window, send the command "powerbtn" to power on again;
