Error code -67032 explains Labview web services: This type of web service is not supported.
Possible reasons: The Labview VI will upload the files to a temp folder and the need admin permission to edit and if the Labview is not run with admin access, it may fail with file upload.
Run LabVIEW with admin mode may solve the issue.
