The difference in bandwidth behavior between the PXIe-5122 and other modules like the PXIe-5922 is due to historical differences in the underlying technology used in NI oscilloscope modules.
Older modules like the PXIe-5122 use undersampling techniques, allowing them to capture signals in the second Nyquist zone. This is particularly useful in spectral measurement applications, where signals are repetitive and predictable.
At the time of the PXIe-5122’s development, it was not feasible to find analog-to-digital converters (ADCs) that offered 14-bit resolution with 100 MHz bandwidth while still meeting Nyquist sampling criteria.
As a result, the PXIe-5122 was designed with a bandwidth equal to its maximum sampling rate to maximize performance within those constraints.
