Windows Occasionally Asserts That nimdnsnsp.dll Is Not Signed Correctly When Opening LabVIEW
Updated Aug 19, 2026
  • System Configuration
Windows assertion complaining that nimdnsNSP.dll is not signed correctly.
I recently upgraded to Windows 11, and since then I have been seeing this warning. How do I resolve it?
This Module Is Blocked From Loading Into the Local Security Authority
The issue is caused by a missing or outdated Microsoft digital signature on the nimdnsNSP.dll file.
To resolve the Local Security Authority warning in LabVIEW 2025 on Windows 11, update the NI System Configuration to the latest version. You can access the download page here: Download NI System Configuration
To check your current version of NI System Configuration:
  1. Open NI Package Manager.
  2. Go to the Installed tab.
  3. Uncheck the "Products Only" filter.
  4. Search for NI System Configuration to view the installed version.
If it's outdated, update it to the latest available version to prevent the warning from appearing.
Note: Before installing or upgrading NI System Configuration, verify the version that is compatible with your software stack. In general, NI recommends installing versions that are supported with your LabVIEW release and other installed drivers. Upgrading NI System Configuration may update shared components used by other NI software. Review the product's release notes and compatibility documentation before proceeding with the installation.
