If you prioritize X-axis alignment across multiple graphs in DIAdem, consider using the “n System [linear]” Y-Axis Option. This setting displays each data set in a separate graph within a single area, which helps align the X-axes more precisely.
Note: This method does not allow stacking multiple data sets on a single graph.
If you need to display multiple data sets in a single graph and compare them with another graph in a separate area, perfect X-axis alignment is not possible. This is due to a cosmetic limitation in DIAdem’s layout engine. As a workaround, you can try adding a variable with empty data to help visually align the X-axis, but it may still not be perfectly aligned.
