I had created a VI in LabVIEW 2024 Q3, which consist of using LabVIEW Report Generation Toolkit for Excel, and I want to run the VI using TestStand 2023 Q4. However, when I tried to do so, an error message appeared. The error message is as shown below:
Unable to load VI 'exExcel1.vi' with the LabVIEW Run-Time Engine version 24.3 (64-bit).
The VI is broken. Please refer to the log file from TestStand for more information.
Detailed log stored at 'C:¥Users¥33216072¥AppData¥Local¥Temp¥TestSTand¥exExcel1.txt'
