I have developed a VI for a compactRIO (cRIO) controller that utilizes EtherCAT communication to talk to an EtherCAT Slave. When trying to run and deploy the VI on the cRIO through a different computer than the one used for developing the code, I always get the following error message during the deployment process:
NI System Configuration operation failed due to general conflicts
If I try to deploy a simpler application on the cRIO that does not contain the EtherCAT functionality on the same computer where the error is displayed, I am able to successfully complete this process.
