This issue is caused by a version compatibility mismatch between DIAdem and USI/DataFinder. You can check your USI/Data Finder version as shown below.
To resolve it, you can try to upgrade the USI version. However, there is currently no standalone method available to download or update USI independently. As a temporary workaround, upgrading the LabVIEW version will also update the USI version accordingly.
