Maintain the VI Path in TestStand when Moving File to Another PC
Updated Nov 20, 2025
  • TestStand
When moving TestStand project that contain VI path to another PC, the reference path is released and we need to set it again. How to maintain the VI path even when moving to other PC?
We have confirmed that the VI path can be maintained even if the folder is moved to another PC using the method below:
1) In Configure >> Search Directories, check the small box next to Current sequence file directory.
2) Also check Search Subdirectories.
3) Then use Move Up to make Current sequence file directory the first directory in the list.
