- NI-DAQmx
- DAQmx 2024 Q3.1 Patch 1
- DAQmx 2024 Q4 Patch 1
- DAQmx 2025 Q1 Patch 1
When either of the above mentioned NI-DAQmx version is installed on Windows host and the Linux RT target system is set up with the provided Linux RT System Image, the "Add Ethernet Device" and "Test Panel" functionality will be broken for the Linux RT target system due to the NI-DAQmx driver version mismatch between the Windows host and Linux RT target system.
