Requesting NI Technical Support for Instrument Driver Network(IDNet)
Updated Jun 10, 2025
  • Instrument Drivers
  • I have a third-party measuring instrument and I want to control it using LabVIEW. When I visit the Instrument Driver Network (IDNet) page to download the drivers, I could not find the correct drivers for my instruments.
  • I download the LabVIEW drivers for my instruments, but when I use the VI(s), LabVIEW reported an error.
  • While I am in LabVIEW development environment, everything is working fine when I use the instrument drivers. However, when I create LabVIEW application, it runs into an error.
Instrument Driver Network (IDNet) is a platform provided by NI where users can find, download, or submit drivers to communicate with third-party instruments such as Agilent, Keithley, Tektronix, etc.
Instruments drivers available in the IDNet are classified based on two criteria:
  1. NI Certified and NI Supported whereby developed by NI R&D and maintained by NI R&D.
  2. Non-NI Certified and Non-NI Supported. This category of driver is provided "as is" and is not supported or maintained by National Instruments or a third party.
Below is the example for certified and non-certified driver respectively.
  • NI Certified and NI Supported driver.
  • Non-NI Certified and Non-NI Supported driver.
If you encountered issue with the NI Certified and NI Supported instrument drivers, you may reach out to instrument.drivers@emerson.com. This email box is managed by NI personnel responsible for managing the certified drivers and assisting on the issue related to it.
If the issues happen on a Non-NI Certified or Non-NI supported driver, you may reach out to your instrument manufacturer for further inquiry or submit request a new driver through this link. Below are few examples of the support channel for the manufacturer that you may use to request support.
  1. Tektronix Technical Support
  2. Teledyne Technical Support
  3. Agilent Technologies/Keysight Technologies Technical Support
The mailbox mentioned above is solely intended for issues rooted to the instrument drivers. If you are not sure if the issue is related to the instrument driver or not, you may reach out to NI Technical Support to clarify.
