The measurement fails because the PCI-6115 and the NI-9775 do not share the same backplane. Therefore, you cannot route the PCI-6115 PFI0 signal to trigger the NI-9775 directly.
To work around this limitation, you can use one of the following methods:
- Use the cDAQ chassis PFI0: Input the digital trigger signal directly into the PFI0 of the cDAQ chassis to trigger the acquisition.
- Bridge the trigger signal: Connect another PFI port from the PCI-6115 to a PFI port on the cDAQ chassis, and input the digital signal there to trigger the acquisition.
