Measuring Voltage and Resistance in One Session with PXIe-4080
Updated May 27, 2025
  • PXIe-4080
  • NI-DMM
Is it possible to measure both voltage and resistance in a single session using the PXIe-4080?
Yes, it is possible to measure both voltage and resistance in a single session with the PXIe-4080. This functionality has been verified using the following LabVIEW code, which allows you to configure and switch between measurement functions within the same session.
