TS-15000
The device supports multiple mounting configurations - direct, side, or bottom mounting - to suit different installation requirements. It serves as an integrated backplane solution that can be incorporated into your existing test fixture setup, offering flexibility in system design and implementation.
TS-15010
This device requires installation in a standard 19-inch 1U half-rack test rack setup. To complete the installation, a separate 19-inch front panel will need to be acquired (P/N: 137987A-01L), which is sized to fit two TS-15010 units across its width. Please note that this front panel is not included and must be ordered separately.
