What Does Maximum Duty Cycle Setpoint Resolution Mean on NI-9470 Specifications?
Updated May 22, 2025
What does the 0.025% maximum Duty cycle setpoint resolution mean in NI-9470 Specifications?
The duty cycle setpoint resolution is 0.025% at most. This means the PWM can only be adjusted in increments of 0.025%, not smaller. For instance, you can set the PWM to 10.025%, 10.05%, 10.075%, etc. If you try to set it to 10.01%, it will round down to 10.0% or up to 10.025%.
For setting up PWM, please refer to How to Generate PWM Signals with a Digital Module
