Converting TestStand Sequence File Using Command Line
Updated May 12, 2025
  • TestStand
How can I convert a TestStand sequence file using the command line with the TestStand Sequence File Converter?
  1. First, change the directory to the folder containing the Sequence File Converter tool:
cd C:\Program Files\National Instruments\TestStand XXXX\Bin
  1. Then, use the following command to convert the TestStand sequence file:
SequenceFileConverter.exe [-Help] [-Recursive] [-Quiet] [-UpdateVersion] [-Unlock:<PasswordList>] [-Format:<Format>] [-Protect:<Mode>:<Password>] <file or directory path> [-env <environment path>]
The following list describes all of the available options you can use in the command line for the sequence file converter:
      • Help: Launches a dialog box explaining the command-line arguments.
      • Recursive: Applies changes to files in directories below the specified directory.
      • Quiet: Disables prompts to confirm conversion and unlock files.
      • UpdateVersion: Saves sequence files with the current version of TestStand even if no other modifications exist.
      • Unlock:<PasswordList>: Attempts to unlock files for editing using a comma-delimited password list. Note: This does not remove password protection.
      • Format:<Format>: Converts all files to the specified format. Possible values are binary, INI, and XML.
      • Protect:<Mode>:<Password>: Protects all files with the specified password. Possible values are Edit, View, and DisableNote: The Disable value removes password protection from all files unlocked during conversion.
      • env<environment path>: Launches the Sequence File Converter tool in the environment defined by the .tsenv file located at the specified path.
  1. Press OK when a window confirming changes pops up.
Example command:
SequenceFileConverter.exe -Format:INI "C:\Users\Public\Documents\National Instruments\TestStand 2021 (32-bit)\Examples\Demos\Mobile Device Test\Mobile Device Test.seq"
This example shows:
  • How to convert "C:\Users\Public\Documents\National Instruments\TestStand 2021 (32-bit)\Examples\Demos\Mobile Device Test\Mobile Device Test.seq" to INI format.
  • The file does not have password protection.
