The goal of this article is to explain the process of integration IO Templates for modular devices created in InstrumentStudio™ and passing them into TestStand for use with LabVIEW code modules.
The steps include creating an IO configuration in InstrumentStudio™, exporting it to TestStand, and using the configuration in TestStand to link the template to an instrument handle saved as a local variable. Finally, the instrument handle is passed into an action step's LabVIEW code module and we discuss the necessary requirements from a LabVIEW perspective.
