This is a known issue. The behavior occurs because the Linux Real-Time OPC UA 22.8 package is not compatible with LabVIEW 2025. This package is included in Linux RT base images 2025 Q1 and 2025 Q2.
The OPC UA software has an NI-SSL dependency for certificate creation. However, LabVIEW 2025 uses OPENSSL for this purpose. Due to this difference, a symbol collision occurs, which is not resolved in NI Linux RT, resulting in the controller crashing. To solve this issue, you have two options:
- Install the Linux RT base image 2025 Q3 or above in the RT target.
- Use LabVIEW 2024 Q3 or earlier.
