Do My NI Switch Relays Keep Their Position When They Are Powered Off?
Updated Oct 22, 2026
  • Switch
  • Switch Executive
  • NI-SWITCH
I am using an NI PXIe-2593 switch module, which is specified as having latching relays. When my system shuts down or loses power, I want to know whether the relays remain in their last position or return to a default state. I also want to understand what happens when the system powers back on.
The behavior of an NI-SWITCH PXI Express (PXIe) module during and after power loss depends on the relay type used by the module.
NI switch modules typically use one of the following relay types:
  1. Latching relays
    • Require power only when changing relay position.
    • Maintain their current position when power is removed.
    • Do not automatically return to a default state during a power loss.
  2. Non-latching relays
    • Require continuous power to maintain relay position.
    • Return to their default state when power is removed.
The NI PXIe-2593 uses latching relays. Therefore, when the module loses power, the physical relay positions remain unchanged.
However, after the host system restarts and the NI-SWITCH driver initializes the device, the driver may configure the relays according to the device's default initialization behavior. As a result, the relay state observed after startup may differ from the state that was physically retained during the power-off period.
The relay state retained during power loss is a characteristic of the hardware relay itself. Any relay state changes observed after system startup are typically caused by software initialization performed by the NI-SWITCH driver or the application controlling the module.
