How to Activate LabVIEW PDA Module Versions After 8.1
Updated May 6, 2025
  • LabVIEW PDA Module
  • LabVIEW Mobile Module
I would like to activate the LabVIEW PDA Module (for Palm OS/for Pocket PC/for Windows Mobile) for versions after 8.1. However, when I generate the activation code through Offline Activation page, it only allows me to generate codes for version 8.1 and lower. The generated code cannot be used to activate version 8.5.1.
The image below shows the LabVIEW PDA Module for Windows Mobile version 8.5.1 in the NI License Manager:
Versions of the LabVIEW PDA Module after 8.1 were renamed to LabVIEW Mobile Module. If you want to activate a version of the LabVIEW PDA Module that is later than 8.1, you can generate an activation code using the LabVIEW Mobile Module.
