Error 7 Occurred When Using VCOM Toolkit in LabVIEW
Updated May 5, 2025
I am using the LabVIEW APIs of VCOM to develop an application for CAN testing.
But I get the following error:
Please check if the file path and name are entered correctly.
  • Example Correct file Path : C:\Users\<username>\Desktop\test\Config2
  •  Check if the path you want to use is correctly written.
  • If the path in the image above differs from the actual file path, Error 7 will occur.
