You can match the graph colors in SystemLink to those in DIAdem by defining a custom report template and modifying the 'Main.vbsa' script to load this template instead of the default one. Within the custom report template, you can adjust the graph colors to align with DIAdem’s color scheme by editing the default color settings accordingly.
The detailed steps for the process described above are as follows:
1) Open the TDR file in DIAdem Report and modify its contents as needed (e.g., adjust graph colors to match DIAdem’s color scheme).
2) Save the modified .TDR file.
3) Replace the existing .TDR file within the .anp project directory, placing it alongside the Main.vbsa script file.
4) Modify the Main.vbsa script to ensure it loads the custom report template created in Step 2.
