Isolation of CAN Bus Signals in PXI-8513/2
Updated Apr 24, 2025
  • PXI-8513
In the PXI-8513/2 datasheet, I have observed channel-to-earth isolation. Does this mean CAN Hi and Lo of each port are isolated from AGND, DGND, and Chassis GND?
Yes, the CAN Hi and Lo at the DSUB-9 connector are isolated from other digital grounds. This means that the SMB connector (used for triggering purposes) references the digital ground, which is shared with the PXIe chassis ground. However, the CAN Bus signals (at the 9-pin DSUB connector) are isolated from the digital ground and chassis ground.
