Customizing DataPlugIn for Excel Using DIAdem DataPlugIn Wizard
Updated Oct 20, 2026
  • DIAdem
In this article, your objective will be to customize the DIAdem DataPlugIn Wizard to define channel names/data from certain cells in an Excel file so that no data is lost when you import an Excel file into DIAdem with the DataPlugIn Wizard.
When importing Excel file into DIAdem, the ExcelTDM DataPlugIn installation is required. Afterwards, the Excel file can be imported and automatically converted to a TDMS format by dragging it to the data portal of DIAdem. The DataPlugIn applied will follow the DataPlugIn priority set in DIAdem.
When Excel's cell data (ex. A2,B3,C5...) imported into DIAdem, classifying these into TDMS formats, Groups, Channels, Channel data. The classification for each data can be DataPlugin Wizard for Spreadsheet Files. This wizard can create your own DataPlugin. The function can be found in DIAdem like below:
In this wizard, the main configuration factors are described in the above documents. There is a few important features.
In File Structure,
Group Properties and Channel Properties can only import horizontal Cell data.
Channel Data can only import vertical Cell data.
In order, Group Properties and Channel Properties can have Ignore in the middle row of Excel, but not the Channel Data.
Cells merged in Excel appear to have duplicate values as individual cells in DIAdem.
In Excel this would look like this:
In the other hand on DIAdem it would look like this:
Group property is a 1-on-1 match between Property and Value. To avoid repetition of duplicate values, cell numbers can be assigned directly to Value values.
If the channel data value contains characters, it cannot be read unless the type is set by Text.
Let's see the example for the customer DataPlugIn process. Below is the excel file to import from DIAdem.
In Wizard:
Step 1: Define the type of file structure as follows
Step 2: Change Value B2 to $C2, which is paired with $A2 Properties.
Step 3: Check the values to be named for each channel.
Step 4: Check the values that will be the channel data.
Step 5:  Save Dataplugin with the name you want.
Finally, an example of an Excel file imported from DIAdem is as follows:
