このコンテンツは設定された言語で表示できません。
Error Activating Windows 11 IoT Enterprise 24H2 on PXIe Controller
Updated Nov 26, 2025
  • PXIe-8862
  • PXIe-8842
  • PXIe-8822
  • PXIe-8881
I found it is unable to activate Windows 11 on the new PXIe-8862, despite the PXIe controller being shipped with Windows 11 OS and a valid license.
Microsoft has identified an issue with the 24H2 update. We have received the following workarounds from our Microsoft distributor.
For Systems Still on 22H2 or 23H2
If your system has not yet been upgraded to 24H2 and is still running on 22H2 or 23H2, please follow these steps:
  1. Apply the latest cumulative updates by using Windows Update::
    • Ensure that you apply the latest cumulative updates when your system is running Windows 11 IoT 22H2 before upgrading to a newer version, 24H2.
  2. Run "SLMGR /REARM":
    • Ensure your system is running Windows 11 IoT 22H2.
    • Open Command Prompt with Administrator Mode.
    • Execute the command SLMGR /REARM.
    • Reboot your system.
    • Your Windows should be activated as usual.
  3. Perform Windows Update:
    • Update your system to Windows 11 IoT 24H2.
    • After the update, your Windows should remain activated.
For Systems Already Upgraded to 24H2
If your controller has already been upgraded to Windows 11 24H2, you must roll back to 22H2 and then perform the workaround described above. To roll back to 22H2, use the Windows 11 IoT Recovery Media.
    • This method involves a clean installation that will wipe all data in Windows.
    • Use the shipping kit: 788832-03 - WINDOWS 11 IOT ENTERPRISE USB RECOVERY MEDIA FOR PXI, MULTILANGUAGE.
    • Use the software kit: 502284B-00 - USB16 KIT, WINDOWS 11 IOT ENTERPRISE 22H2 USB RECOVERY MEDIA FOR PXI, MULTILANGUAGE.
