This feature will be helpful when dealing with large data files such as a 30 GB data file. Without this feature, unless the machine itself has more than 30GB of memory, DIAdem will not be able to load those data into the memory for the upcoming data post-processing. With this feature enabled, memory consumption when dealing with large data files will be significantly reduced because data is virtually saved by DIAdem hence disk space is used instead.
All the data saved virtually as files in the mentioned path by DIAdem will be removed when DIAdem is closed. If DIAdem crashed and these files are not removed automatically, you may removed them manually. Below is how these files look like:
