Unexpected Error Occured When Opening Properties of the Module
Updated Apr 14, 2025
I have a LabVIEW project that includes a real time target in it. When I right-click on the module and select Properties it pop-ups:
An Unexpected Error ocured
In most cases, this error occurs because a required driver is not installed or the installed version is incompatible. Read the documentation of the device and use NI knowledge base to get information about drivers' compatibility.
