If nothing from the steps above helped resolve the issue, reinstall the OS or do reimaging.
You can also run the VeriStand Gateway silently to check on the Gateway's status:
- Open a command prompt.
- Execute the start command using the following syntax: "<Base>\veristand-server.exe" start.
This will start the server if it is not already running. This way, you can analyze the behavior of the program.
