Using Band Cursor in TDMS File Viewer via VeriStand
Updated Apr 10, 2025
  • VeriStand
When using the VIEW tab in DIAdem, the band cursor function allows comparison of time and value between two points. However, when opening the TDMS File Viewer through VeriStand, the band cursor is not visible. Can the band cursor function be used in the TDMS Viewer?
Unlike the VIEW tab in DIAdem, the band cursor is not visible on the toolbar in the TDMS File Viewer. However, you can still use the band cursor function by right-clicking the graph and selecting Cursor>>Band.
