Where can I find the .dll/.lib/.h file for niRFSA and niRFSG drivers?
For 64-bit version:
For 32-bit versions:
You need to make sure you check the box for NI-RFSA/NI-RFSG Support for .NET Framework Languages and Support for C as below during the driver installation to use the drivers under C programming or .NET framework.
