Archived:Can I Use Macros on NHR 9200 and 9300 Power Modules in Parallel?
Updated Nov 10, 2025
System
  • NHR-9200
  • NHR-9300
When I have my NHR 9200/9300 power modules in parallel, I notice the option for macros is grayed out.  Is this expected behavior?
Yes, macros for NHR 9200/9300 power modules are only meant for single module use.
Our recommendation for paralleled modules will be to use a programming environment, such as LabVIEW, to program a sequence of commands you'd like to perform.  This can be done with the NHR driver or using SCPI commands.
