If you are able to get the expected images using OpenCV, consider integrating OpenCV with LabVIEW.
There are two possible methods for this:
Using VisionOpenCV Utilities
This approach connects NI Vision image data with OpenCV data using C++. Knowledge of C++ development is required.
The utilities can be downloaded via the VI Package Manager.
Using OpenCV for LabVIEW
This method allows you to use various OpenCV functions in LabVIEW via Python.
If you only use the APIs published on GitHub, no knowledge of Python development is required, but you do need to have a Python development environment installed.
Note that images are acquired in picture format, so if you want to use Vision Development Module functions after acquisition, you must convert the image to the IMAQ Image data type.
This tool is available on the corresponding GitHub page.
