Changing the Measurement Time in Veristand Pulse Measurement
Updated Jul 6, 2026
  • VeriStand
I am making pulse measurements using a CI task on a DAQ channel in VeriStand.
When measuring the frequency or duty ratio of a pulse, the value may be returned as NaN when measuring a low-frequency signal. Is it possible to change the measurement time?
Before deploying a VeriStand project, you can configure the timeout value through "Select channel type to add" and choosing the CI option from the drop-down menu.
Depending on the frequency of the measurement signal, adjusting this value may produce the desired results, therefore, it is recommended to modify it.
