Error -50103 at DAQ Assistant When Two Edge Separation Function Is Used
Updated Apr 2, 2025
I want to read the time between two edges on 2 different pairs of digital lines, but receive an error 50103 at DAQ Assistant.
What is the root cause of the issue?
Make sure each pair of digital lines is connected to one counter. Each counter can be used only for one Two-edge separation operation.
