Copying the VIEW sheet in NI DIAdem is not natively supported.
However, you can use the following script as a workaround to achieve this functionality:
vbscriptCopyEditOption Explicit ' Forces explicit declaration of all variables.
Dim ActiveSheetIndex, i, n, n1, n2
i = 0
ActiveSheetIndex = View.Activesheet.Index
n = View.Sheets.Count
' Save the current layout to a temporary file
Call View.SaveLayout("C:\Users\Public\Documents\National Instruments\DIAdem 2024\Documents\Example.tdv")
' Append the saved layout to create a copy of the active sheet
Call View.AppendLayout("C:\Users\Public\Documents\National Instruments\DIAdem 2024\Documents\Example.tdv")
' Calculate the range for removing unwanted sheets
n1 = n + 1
n2 = n * 2
' Remove all sheets except the copied active sheet
For i = n2 To n1 Step -1
If Not (i = ActiveSheetIndex + n) Then
Call View.Sheets.Remove(i)
End If
Next
