Step 1 : Set up the unique identification of the names in target VI as follows
So you will be able to get the read names for the target that can communicate the first application in the host. <You will set up and send the variable context to the first host application.> The variable Context will look like Read/Arb684
You will repeat the process for the endpoint you want to specify, in this case, two similar target read endpoints will be created using the name methodology.
Step 2: Send the shared variable to pass the identification to the host
The URL you specified here will be like //10.144.130.151/Read/Arb684 <The IP address is the target IP, and the string after it is coming from the shared variable you passed from the target application>
Step 3 : Set up the communication for the host application as above and you will able to realize the function for two different applications communicate and stream with the target applications at the same time.
