1.Compare the example code between niUSRP EX TX Continuous Async.vi and niUSRP EX Tx Multiple Output(Single Device, Multiple Channel).vi.
1>The niUSRP EX Tx Continuous Async.vi example used the property Enabled Channel and niUSRP Configure Siganel.vi ;
The niUSRP EX Tx Multiple Output(Single Device, Multiple Channel).vi example used properties:Active Channel , Carrier Frequency , Gain and Active Antenna multiple times for each channel ;
2.Try to modify the niUSRP EX Tx Continuous Async.vi example code using adding properties (Active Channel , Carrier Frequency , Gain and Active Antenna) for each channel , like below picture:
