Using 10 MHz REF IN Connector of PXIe-1090 for Clock Export
Updated Mar 24, 2025
  • PXIe-1090
I want to export a clock from the PXIe-1090. Can I use the 10 MHz REF IN SMA Connector to send the clock to another chassis?
You cannot use the 10 MHz REF IN SMA Connector on the PXIe-1090 chassis to export the clock as this connector is used only to accept an external 10 MHz reference clock.
