What Is The Minimum Baud Rate of PXIe-8510
Updated Jul 14, 2026
  • PXIe-8510
  • NI-XNET
I want to use PXIe-8510 for CAN communication. I went through the PXIe-8510 specification and could not find any information related to the minimum baud rate. What is the minimum baud rate of PXIe-8510?
According to PXIe-8510 Specification, PXIe-8510 requires NI-XNET transceiver cables for CAN communication. The minimum baud rate supported by the transceiver is determined by the protocol. For High-Speed CAN, Low-speed CAN and CAN FD, the minimum supported baud rate is 40 kbps.
