Can I Install Multiple Versions of Vision Builder AI on One Computer?
Updated Mar 28, 2025
  • Vision Builder for Automated Inspection
Is it possible to install multiple versions of Vision Builder Automated Inspection (VBAI) on the same computer?
Yes, you can install multiple versions of Vision Builder Automated Inspection (VBAI) on your PC. Please ensure that the installed version of Vision Builder AI is compatible with the version of LabVIEW on your system.
If you have an inspection built in an older version of VBAI, you can open it in a newer version without issues. However, if you save the inspection using the newer version, VBAI will update its version, making it incompatible with the older version. To keep compatibility, avoid saving older inspections in a newer version unless needed.
