Generating a Windows Dll File for Custom Checksum with Visual Studio.
Updated Jun 9, 2025
  • Vehicle Communication Toolkit
  • NI-XNET
To implement custom checksum with NI-VCOM on Windows, the dll file is needed. This article will introduce how to setup the compile toolchain to generate the dll file for custom checksum on Windows.
  1. Create a new project in Visual Studio(Community version is enough).
  2. Select the project template Dynamic-Link Library (DLL).
  1. Save the project by clicking Create.
  1. Delete dllmain.cpp and pch.cpp files in Source Files.
  1.  Add your cpp file containing the algorithm code by right-click Source Files->Add->Existing Item...
  2. Delete pch.h and framework.h in Header Files.
  1. Add the header files nixnet.h and NIXNETCustomInterfaceCAN.h by right-click Header Files->Add->Existing Item...
  1. You will see the error "unexpected end of file while looking for precompiled header. Did you forget to add ‘#include "pch.h"’ to your source?". This error can be resolved by following the steps below:
    1. In the Solution Explorer window, right-click the project name, and then choose Properties to open the project Property Pages dialog.
    2. In the Configuration drop-down, select All Configurations.
    3. Select the Configuration Properties->C/C++->Precompiled Headers property page.
    4. In the property list, select the drop-down for the Precompiled Header property, and then choose Not Using Precompiled Headers. Choose OK to save your changes.
  1. In the Solution Explorer window, right-click the Solution, and then choose Build Solution.
  2. In the Output window, the Build process is successful.
  1. In the Solution Configurations drop-down, select Release, and then build solution again.
  2. The Output window should show the messages as below. The dll file is located in D:\Work\NI_VCOM_Windows_XYZ\DLL\x64\Release.
An example project is attached. You can find the header files and cpp file mentioned above. You can use the project as it is.
