How to Merge the Test Socket Execution Windows in TestStand?
Updated Sep 12, 2025
  • TestStand
This article outlines the steps in order to merge the test socket Execution Windows into a single Windows, especially when running Batch process models.
To merge all the test socket Execution Windows, follow these following steps.
  1. Click Configure at the TestStand menu bar and select Model Options.
  2. When the Model Options windows appear, under the Multiple UUT Settings, make sure to disable the Tile Execution Windows. If this option is enabled, the user interface application will arrange the test socket Execution windows in separate windows so that they will not overlap.
  1.  Click OK to complete the process.
