Compatibility of Semiconductor Device Control (SDC) Base Add-On with InstrumentStudio and Python
Updated Mar 12, 2025
  • USB-8452
  • InstrumentStudio
Other
Python
I just bought USB-8452 together with the Semiconductor Device Control (SDC) Base add-on and planning to use it for SPI Device Control. I am planning to control it by InstrumentStudio and even Python. Are there any compatibility that I should take note for this add-on?
For InstrumentStudio, the software versions supported by the Semiconductor Device Control (SDC) add-on are version 2023 Q3 or above (64-bit only). As for Python, the add-on supports Python version 3.7 to 3.12 (64-bit only). You can refer to Semiconductor Device Control Add-On Application Software Support for other product compatibility for the add-on.
