USB-8452 Support for xSPI (Extended SPI) and OSPI (Octal SPI)
Updated Nov 20, 2025
  • USB-8452
Does the USB-8452 support the xSPI (Extended SPI), and OSPI (Octal SPI)?
the USB-8452 does not support xSPI (Extended SPI) or OSPI (Octal SPI). The primary reasons for this are:
  • Single Data Lane Limitation: The USB-8452 only supports a single data lane, which is insufficient for Octal SPI.
  • Lack of DDR Support: The USB-8452 does not support Double Data Rate (DDR), a requirement for xSPI.
  • Increased Data Rates: The significantly higher data rates specified by xSPI exceed the capabilities of the USB-8452.
  • Technical Constraints: Other inherent technical limitations of the USB-8452 architecture prevent it from supporting these advanced SPI protocols.
These factors collectively restrict the USB-8452 from accommodating the requirements of both xSPI and OSPI.
